Receiver differences | SatelliteGuys.US
Rinker97
74
Hi all,
I was looking at systems from Solid signal and saw msny different receivers. What is the difference between the SD receivers D10 and the SD-HBH Director Pack Receiver? On teh HD side, what's the difference between the TS360 and the DTC210?
Also, I see where Value Elect has the HR10-250 with a 5 year warranty. Has anybody had to use the warranty yet? I was wondering about the company that handles the warranty work and how they do it.
I'm ready to get DirecTV I'm just trying to learn all I can and make the right choice for me.
Rink
Your likely to get 1000 hard to read replies and it might be easier to go to the D* website and compare the user guides. You should also compare some models that are just out of production for better feature per dollar value; as well as better styling. Generally there are only minor differences in features, software/firmware and ergonomics.
Question about Direct TV Local and Distant network feeds
Running RG6 through conduit
