Receiver Updating for Bell | SatelliteGuys.US
STINER24
nyc
Hello,
Any suggestions on what channels should you leave on to have your receiver take a regular update (programming guide and ect)
I have a 3100 and 6131.
Channel 198 maybe?
Iceberg and posters, thanks for your help with giving me information on canadian programming in the US, very informative, appreciate the help very much.
Regards...
actually channel number is irrelevant. The guide is on 91W and updates at night. To force the guide to load, do a soft reboot (press and hold down power button on receiver until it goes out then release) or a check switch (that forces the guide too)
With your 3100, removing the smart card and re-inserting also causes a reboot and a full Guide download.
I will have to see if inserting any kind of card into the 6131 will do the same, I seem to remember that it used to but it has been a long time since I tried that.
It is also important to turn off the receivers overnight, when not in use.
