sure I can. select 3 series to record that will all broadcast an episode at the same time..
And you get a message on the screen before hand asking which ones you want to record.
Could it be a new feature and is showing it's a Repeat, OR that it's an episode that you already had recorded ?
I noticed your an hour or so prior to in the guide, so it was nothing to do with to many things happening.
Also noticed that the next show was also the same show, and it didn't do that.
I could not find anything else being recorded at that time
Don't think it's new, but, I think you're spot on with the repeat, already recorded or #3 priority.
Just went through the whole guide and only one other show is recording at that time. Actually, it was 5:10 to 6:10, so there was overlap into 6:00pm. There were no other shows in the 6pm slot. The most would be two, counting this oneIt means you have that program set to record but another program has priority over it, like Hifi said.
this is pretty close.I am seeing this again on my guide .what I am noticing is 2 recordings scheduled in the next half hour and the third in the next hour .the third recording is interfering with the end of the other two recordings.this happened earlier today and I was asked which recording i wanted to cancel about 2-3 minutes before the next recording.that next recording had an x on it.makes sense? Lol.Don't think it's new, but, I think you're spot on with the repeat, already recorded or #3 priority.
not sure how D* does their timers but E* has default settings that start one minute early and run three minutes after the showthis is pretty close.I am seeing this again on my guide .what I am noticing is 2 recordings scheduled in the next half hour and the third in the next hour .the third recording is interfering with the end of the other two recordings.this happened earlier today and I was asked which recording i wanted to cancel about 2-3 minutes before the next recording.that next recording had an x on it.makes sense? Lol.
Yep these settings are adjustable with D*not sure how D* does their timers but E* has default settings that start one minute early and run three minutes after the show
Limited time offer
