Recording a show? | SatelliteGuys.US
Recording a show?
Carta
63
Northeast PA
I have an HR22...I recorded American Idol last night.. It recorded for 1 hour; but AI went on for maybe 5 mins more. So, I missed the last 5 mins.... I guess the DVR only records for the 1 hour increment .. Why wouldn't it tape the whole show? Is this normal?
absolutely normal you need to pad the time if you expect the time to exceed the programm time. Read your instruction book.
I time shifted my viewing about a 1.2 hr. I noticed that no way would it end before 9.
So while watching, I padded the recording another 15 mins.
List,
Highlight the show recording / ENTER
Arrow down to "recording" / ENTER
Slide over and change the recoding end time and change from on time to whatever you want. I selected 15 mins.
All this while watching the recording.
Also most TV shows I pad by 15 mins. You never know.
That is certainly true for any live show. You can blame Tatiana Del Toro for last night's over-run.
Look at the time it is scheduled to go off ... I hate it when a show decides to do that, it pushes everything else out of wack and the rest don't record properly, I'm amazed that they are allowed to do that.
Check and notice what time the show says it will be going off, sometimes it will say 8-9:05 or something like that, in that case, YES the recorder WILL record it.
Jimbo
Alignment help
On Demand Setup with Wireless Adapter
