Guess you missed my edit
Yep, was responding while you were editing apparently. Some people like to have a different amount of padding I guess.
Timer padding does not work using PTAT . It cuts all programs off at the end of the show and there is no padding so you miss the end of most shows. For example if the show ends at 7:30 pm on the guide it cuts off the show exactly at the half hour and you miss the ending and the credits. The networks do this to make you stay on their channel . By padding two minutes late and start one minute early I never miss the ending of any show or the beginning . Now the exception to this is Saturday Night Live. I have to set it for 2 minutes early and 2 minutes late to catch the opener and the ender of that show.Almost everything I record is from PTAT. Is there any way to get the padding to work on PTAT?
And why is Mike setting the padding himself if the Hopper already does it?
I have my Timer Defaults set for 10 minutes late. My PTAT is turned on full strength, all four Prime time channels and eight days. We only usually have the sports run over issue on Sunday CBS. So to get around that issue I have a manual weekly timer set for Sunday to fire off at 10 PM CST for two hours. This has worked great for me since I have been on Hoppers.Timer padding does not work using PTAT . It cuts all programs off at the end of the show and there is no padding so you miss the end of most shows. For example if the show ends at 7:30 pm on the guide it cuts off the show exactly at the half hour and you miss the ending and the credits. The networks do this to make you stay on their channel . By padding two minutes late and start one minute early I never miss the ending of any show or the beginning . Now the exception to this is Saturday Night Live. I have to set it for 2 minutes early and 2 minutes late to catch the opener and the ender of that show.
Are you saying you got the padding to work with PTAT?I have my Timer Defaults set for 10 minutes late. My PTAT is turned on full strength, all four Prime time channels and eight days. We only usually have the sports run over issue on Sunday CBS. So to get around that issue I have a manual weekly timer set for Sunday to fire off at 10 PM CST for two hours. This has worked great for me since I have been on Hoppers.
No, I do not mess with the PTAT except turn it on. I have the manual Sunday weekly timer to catch anything that runs over for CBS only.Are you saying you got the padding to work with PTAT?
Looks like there really isn't a solution for me then. I can't turn off PTAT on any day of the week because I'd have to set the timers for each show manually and it wouldn't be long before I missed a show or two and I have people yelling at me.No, I do not mess with the PTAT except turn it on. I have the manual Sunday weekly timer to catch anything that runs over for CBS only.
Why turn it off unless you have hard drive space issue. I loved it since day one. I keep the setting at eight days. You don't ever have to worry about setting any timers for PTAT programs. For me I have issues with the timer limits. Right now I am up to 190. I am going to have to do a surge soon before I hit the 199 limit.Looks like there really isn't a solution for me then. I can't turn off PTAT on any day of the week because I'd have to set the timers for each show manually and it wouldn't be long before I missed a show or two and I have people yelling at me.
Exactly, I don't want to turn it off and I won't. It's just the padding issue that doesn't really seem to have a solution.Why turn it off unless you have hard drive space issue. I loved it since day one. I keep the setting at eight days. You don't ever have to worry about setting any timers for PTAT programs. For me I have issues with the timer limits. Right now I am up to 190. I am going to have to do a surge soon before I hit the 199 limit.
I don't think we ever start watching the first recording of the night first but I'll see if we can give it a try.PTAT records a solid stream from the 4 big networks, not individual programs. If you start watching the first program recorded on PTAT and never stop it it will play the entire evenings recordings for that channel. Saving PTAT outside PTAT is a totally different animal, it uses marker in the recording to estimate the start and end of the programs - might not be precise.
Thanks Jim5506, I did not know that. I just tested it and you are correct. When did they start that one steady stream? It wasn't that way a while back. I had wondered why lately I haven't had to rely on my weekly CBS Sunday 10 PM manual timer. I guess I will keep the manual timer in case the last PTAT program of the evening runs out sometime. I hardly ever watch the last one but will be ready if I do sometime. The manual timer will come in handy then.PTAT records a solid stream from the 4 big networks, not individual programs. If you start watching the first program recorded on PTAT and never stop it it will play the entire evenings recordings for that channel. Saving PTAT outside PTAT is a totally different animal, it uses marker in the recording to estimate the start and end of the programs - might not be precise.
Well when I had HWS I always had trouble with 60 Minutes. It would start late do to a sports overage program and then end too soon. I had to go to the next program to finish it up. Of course then the next program would end too soon and on and on till I had to watch the manual timer I had set. I am glad it now has a solid stream. Sure works good till the last PTAT program of the evening.I think the solid stream is how it was designed, actually 4 solid streams.
I discovered it during football season. When games ran over, the start times of the individual shows were left as originally programmed but I could watch the programs straight through, usually missing the end of Madam Secretary, so I set the local CBS station news to record and was able to see the end of Madam Secretary.
That is the way it works unless the show has AutoHop available, and you use that feature. Those shows usually stop at the end of the time slot, instead of playing the next show.PTAT records a solid stream from the 4 big networks, not individual programs. If you start watching the first program recorded on PTAT and never stop it it will play the entire evenings recordings for that channel.
If you hardly ever watch the prime time four main channels I can understand leaving it turned off. For us that watch a lot of prime time I think the PTAT is awesome. I don't ever have to be concerned setting up timers for the four prime time channels. I have more problems of hitting the 199 timer limits so PTAT is a blessing. I also don't have issues with the internal HD filling up. Some of us still get AutoHop for NBC and ABC which is awesome. Also it is nice to have all them PTAT recordings in case I missed a program or look for something to watch. So there are a few reasons that I like PTAT.I never used PTAT, sop I never had this problem. I know there's no changing people's minds or habits in most cases, but PTAT befuddles me. For one thing, most of the shows on network TV are junk - my opinion - so I don't see a need to record every show on all 4 channels every night. I mean, the sitcoms aren't funny and the cop shows are the same show over and over. Regardless, I set timers for the shows i do want and so far, other than a very rare blip here and there (Rosanne ep. 5), no real problems. I guess my question is this; What is the allure of PTAT, other than autohop, which has been hobbled a bit anyway?
I am needing to do a clean out timers too. Getting close to the 199 limit again. Who the hell is Chris Angel? I missed that program along the way!I can understand that. I actually need to clean out my old timers. Like, I'm Pretty sure Chris Angel - Mind Freak isn't coming back lol
Limited time offer
