Both my Joeys are showing a red MoCA signal icon in the system diagnostics. Yet full bars on the icon. What does that mean?
3HaloODST said:Sounds like an issue with the MoCA. What are your MoCA stats? YELLOW - BLUE - 3 - VIEW COUNTERS - PAGE DN to MoCA stats.
training pdf has a listing of the following:
- Maximum 200-foot cable length from LNBF to farthest Hopper
- Maximum 200-foot cable length between any Hopper and Joey
3HaloODST said:The worst RxPower is about -63 so your device using the existing cables and 160-180ft (200ft is the max) has some issues. Are the existing cables RG6?
According to Dish, ANYTHING other than full green bars is unacceptable for the installer to leave in place.
The installer didn't leave it this way. I moved the Joey to a further room. Checking the cabling, it's RG59. I'm buying new cable tomorrow.
Its the cabling or it could also be the splitter. Don't use a cheap $3.99 splitter, the better quality one you buy the better luck you are going to have with MoCA.![]()
Limited time offer
