Most likely the RG59 was causing signal reflections as generally it's not a good idea to mix RG59 with RG6. So say from the node to the splitter was RG6, then you ran RG6 to another room, while the other room still uses RG59, reflections from the difference in capacitance would cause excess noise.
I agree. One of my Joeys is on a 20ft run of new RG6 installed by E* spliced to 15ft of 25 year old RG59. It works fine and shows a RX rate of 293+Mbps and -18 dBm Rx power.Any change in impedance in the coax will cause attenuation further down the line, and an inverted reflection in the reverse direction. But RG59 and RG6 have the same impedance, so why would a splice cause reflections? Crappy splice? Is one of these coax lines unterminated?
Big difference between 15ft and 100+ft of RG59. Also, impedance isn't all that matters. Capacitance also matters. RG59 tends to have higher capacitance.
Limited time offer
