Remote problem | SatelliteGuys.US
Remote problem
freeman543
31
us
I just got rid of my 611 hd receiver and want to hook up that tv as a mirror or second tv off my 722 ( it would be the second mirror and i have this extra remote now, in other words one primary and two second tvs of that one receiver ). The 611 remote has a #1 green tab in it and I cannot get it out. I need to put in a # 2 blue tab. Why wont it come out? also is it possible to use the # 1 tab or uhf pro because I don't have any more # 2 tabs ( I could steel one temporarily from another remote just to program the remote. so bottom line I am out of #2 tabs and I cant get the #1 tab out anyway......any suggestions?
If it only says ir, it is not change able, nor does i have tv 2 capability as it is not UHF. Only IR (infrared).
Thanks Dishman1978.......I'll save it as an extra for tv1.......guess i'll just bring the #2 remote from room to room until i get a uhf remote. Glad i didn't force the tab out. I actually have a third remote with uhf but it has a small drain on it and i have to change the batteries every 2 weeks. I 'll leave that one in the spare room and just remove the batteries. Its a room more for company anyway.
Dish America Channel Lineups?
Local channels from different city!
