Remote won't turn off TV set and Receiver at the same time. | SatelliteGuys.US
hoos51
167
My remote will not do this. Called customer service and programmed the remote for my Hitachi Ultavision set.
I have to turn the receiver off using the on/off button and the slide the little goober into TV mode and use the power button to turn off TV.
Vice Versa to turn on, minor issue, is this because of the age if my set?
Unfortunately not all tv's work with all universal remotes. D* does a great job with making it compatible with most of the sets out (new and old) But there are some that it either doesn't work on at all or it works partially. If you have gone through all the codes and code search and still can't get 100% functionality then that's that.
I work for the company and have to use 3 remotes to operate my system :( Eventually I will get a learning remote.
U.S. Open golf in hd??
Spring Cleaning
