Remove Misc. Options | SatelliteGuys.US
Former member 134676
1,167
24
I'm no longer doing CE testing on my Genie after weeks of my Genie freezing. Is there a way to remove the Misc. options?
Sent from my iPhone 5 using SatelliteGuys Reader App!
I would say no but maybe someone that knows more could tell you better :)
Force a download of the national, that should fix it, if not a total system reset through the menus will, but that will also wipe your hdd.
Sent from my PG06100 using Tapatalk 2
I really don't know what the Misc info is causing in this case that removing would change anything. :confused:
I agree w u jimbo, just putting my 2cents in on the topic. I wonder if entering imanedgecutter a second time would work?
I doubt it, as that originally activated it, doubt that it will take it away, but would not hurt anything to try.
As they already said force the national release and forget the misc icon.....Sit back and enjoy..
HR34 CE Release 5/3 (No HR44)
HR34 / HR44 CE Release 5/10
