is there any way to remove the PPV channels from the HD guide? And for that matter, shouldn't only the channels I purchase show up in that guide as well; ie movie channels?
TIA,
Andrew
TIA,
Andrew
Also, if you notice, the channels that you do not rec. are now in a light blue vs the dark blue for channels you DO get.
Jimbo
I would have never figured that out in a million years! But yes - they need a software fix. Why should I waste time creating fav list when every other cable company offers this simple feature? They can even leave the PPV in (for marketing reasons) - it is the channels over 300 that should be removed if you don't get them.
A couple of more "custom" guides would be nice. When i had Ultimate TV, you could create all the custom lists you wanted to.
I would have never figured that out in a million years! But yes - they need a software fix. Why should I waste time creating fav list when every other cable company offers this simple feature? They can even leave the PPV in (for marketing reasons) - it is the channels over 300 that should be removed if you don't get them. agregjones;1266396 said:Not every cable company offers that feature. Suddenlink (formerly Cox) in NC is one example.
I'd like to be able to see a description of the channel while I'm setting up my favorites list. Sometimes I just don't know what a channel is and why I might want it.
I open this page as I set my favorites and it really helps:
List of DirecTV channels - Wikipedia, the free encyclopedia
The list is not accurate on the mpeg 2 channels that are remapped to the higher channel numbers. It lists them as mpeg 4 and the are still mpeg 2That's a great list. I think that link should be made a sticky.![]()
Limited time offer
