That is all correct, Edmund, so how can you tell if you have a RC16 (dedicated D10), RC23 (universal without RF capability) or RC24 (universal with RF capability) remote? It's simple. The RC16 has no Format button in the upper left corner of the remote, while the RC23 and RC24 do. The RC24 has a mandatory FCC Part 15 sticker ( for its RF module) on the remote's back. The RC23 usually has "RC23" printed on it somewhere.Edmund said:Many buying the $15 white remote are getting the Rc16/ urc-1081 remotes, works great on D10/r15 receivers. But only control tivos partially, because the only SAT codes it accepts controls D10 series of sats. There is a code you can program only on the AV1 or AV2 devices, 20618, but many of the keys, like GUIDE are locked to the DTV symbol device and it only controls d10/r15 and alike receivers
Limited time offer
