Replacing 622 with 211k - have a question | SatelliteGuys.US
yaz96
Baby, It's Cold Outside
12,829
Front Range, Colorado
Can I use the power inserter that I needed with the 622 with the 211, or do I need to remove it?
Will it hurt if I leave it in?
Are there any other receivers that use that power inserter?
Do you mean the power inserter for a DPP44 switch that you have installed? If you have a DPP44, you do need to keep the power inserter, and it would work fine with the 211.
Topeka Fox 43
6.3 UHF Remote
