Tiger direct has 200gig maxtors for 129$...markusian said:WOW! This is really good news. Thank you Faw.
Now the next step, who is willing to try a bigger drive?
-Mark
-Mark
If it was creating partitions from some setting in the firmware, wouldn't it just create the same size, regardless of hdd capacity? Of course, there is a chance that it might use the remaining free space to its maximium. But, knowing that the 522's firmware always sets the same size partitions regardless of hdd capacity, I'd say it was a good chance that the 721 does the same.markusian said:WOW! This is really good news. Thank you Faw.
-Mark
Can you clarify this part? Did you use a Linux PC? Or, did you use Norton Ghost on a Windows PC? If the latter, are there any specific settings to get it to copy it as a Linux partition, or does it always copy partitions in their native format?Faw said:I
After this I restored the first partition with the Linux OS from a Ghost Image I created from the bad disk. I was lucky the bad sectors where in the other partitions. I installed the disk back in the 721.
GaryPen said:If it was creating partitions from some setting in the firmware, wouldn't it just create the same size, regardless of hdd capacity?
GaryPen said:Can you clarify this part? Did you use a Linux PC? Or, did you use Norton Ghost on a Windows PC? If the latter, are there any specific settings to get it to copy it as a Linux partition, or does it always copy partitions in their native format?
Drive Size
(*:\) 250MB
(*:\) 1024MB
(*:\) 1024MB
SWAPSPACE(*:\) 128MB
(*:\) 114819MB
That is VERY interesting news. If so, it may indeed be possible to increase storage capacity on a 721!Faw said:I installed the 60GB drive and the last partition was ok, but since the disk was also bad I didn't tested it. Maybe it just uses the remaining of the disk for the last partition, regardless of the size. The first 4 partitions are fixed though, I guess if you install a something less than a 4GB disk it will crash since it wont have space for the first 4.
dssturbo1 said:Hey Faw, did you use Ghost 2003? heard the newer Ghost versions had issues.
Guys be careful with Ghost it can be buggy as it works from DOS. It locked my pc with sata HDs and sata raid up big time. I had to go back to an older computer just to use Ghost without a lockup.
dssturbo1 said:seen other reports that a larger HD will not work in the 721, sorry guys. Think the limit is built into the flash on the motherboard.
<skip>
Smith said:I think the limit exist in DishLinux kernel. We'd discuss it here and at DBStalk - LBA28 vs LBA40.
David_Levin said:Smith, I've used unix/linux systems at work, but never set one up.
Don't suppose you could write a couple of lines explaining these file system terms.
Limited time offer
