Report any lost stations after the 2/17 digital transition (Updated 2/19) | Page 3 | SatelliteGuys.US
Station Callsign: WUSI
Digital Channel Number: 16-2 and 16-3
Acquiring via DirecTV LiL or OTA: OTA
Your DirecTV Receiver: HR21-700
Your DMA: Terre Haute, IN
Your Primary Zip Code (on DirecTV receiver locals setup): 62454
Your Secondary Zip Code (again on the receiver locals):
Did you re-do Antenna Setup (for OTA): Yes, several times.
I can pick up all three 16-1, 16-2, and 16-3 on the Tv, so I know they are broadcasting. However suddenly after February 17th, I lost 16-2 and 16-3.
WUSI dropped their analog signal on February 17th, but their digital channel never changed from channel 19, so I do not know why I can no longer pick up the subchannels with the AM-21. I have rebooted my receiver, I have reset the OTA settings and started over. Nothing works.
Edit: I forgot to mention, the interesting part is, if you check the antenna signal strength, it shows about 70% on 16-1, 16-2, and 16-3. Still can't tune the subchannels however.
No change. Still can't tune 16-2 or 16-3.
This one is now working - thx to whomever got it fixed! :)
Station Callsign: WAND-DT
Digital Channel Number: 17-2
Your DirecTV Receiver: HR20-100
Your DMA: Champaign-Decatur-Springfield
Your Primary Zip Code (on DirecTV receiver locals setup): 62704
Your Secondary Zip Code (again on the receiver locals): none
Did you re-do Antenna Setup (for OTA): yes
Reportedly fixed as of 2/26:
KALBDT2 Alexandria
KLPADT Alexandria
KFNBDT Casper
KGWCDT Casper
WAHUDT Charlottesville
WVAWDT Charlottesville
WCJBDT2 Gainesville
KOAMDT Joplin
KLTLDT Lake Charles
KLCWDT Lubbock
KMYLDT Lubbock
KXTQDT Lubbock
WGBCDT2 Meridian
KTMFDT Missoula
KAQYDT Monroe
KLTMDT Monroe
KTVEDT Monroe
WCOVDT2Montgomery
KTVODT Ottumwa
KYOUDT Ottumwa
CGEMDT Quincy
WGEMDT Quincy
KHSDDT Rapid City
KSANDT San Angelo
KXIIDT Sherman
KMVTDT Twin Falls
WWNYDT Watertown
WGTVDT Atlanta
WVIIDT Bangor
WLPBDT Baton Rouge
WBIQDT Birmingham
WCAXDT Burlington
WITVDT Charleston
WHIODT Dayton
KDSMDT Des Moines
WHO DT Des Moines
KOGGDT Honolulu
KMBCDT Kansas City
KLPBDT Lafayette
WPXMDT Miami
WREXDT Rockford
KLTSDT Shreveport
KCAUDT Sioux City
WSBTDT South Bend
WIBWDT Topeka
KWTXDT Waco
WSAWDT Wausau
WSFXDT Wilmington
WWAYDT Wilmington
WECTDT Wilmington
KNDODT Yakima
Still being worked on:
KXVADT Abilene
KCWYDT Casper
KGWCDT2 Casper
KGWLDT Casper
KFJXDT Joplin
WMEMDT2Presque Isle*
WTRFDT2 Wheeling-Steubenville
KCENDT Waco
Station Callsign:WSEC
Digital Channel Number: 14-2 and 14-2 Subfeeds
Your DirecTV Receiver: HR20-700
Your DMA: Springfield, IL
Your Primary Zip Code (on DirecTV receiver locals setup): 62701
Jason Thank you for the update!!! The Lubbock TX channels are still not correct. Here is the correct line-up. KMYL-DT (KLCW-DT2) 14.1- MyLubbockTV KLCW-DT 22.1 - CW KXTQ-DT (KLCW-DT3) 46.1- Telemundo Station Callsign:KMYL-DT (KLCW-DT2) - MyLubbockTV Digital Channel Number: 14-1 Acquiring via DirecTV LiL or OTA: OTA Your DirecTV Receiver: HR20-100 Your DMA: Lubbock, TX Your Primary Zip Code (on DirecTV receiver locals setup): 79423 Your Secondary Zip Code (again on the receiver locals): 79424 Did you re-do Antenna Setup (for OTA): Yes Station Callsign:KLCW-DT 22.1 - CW Digital Channel Number: 22-1 Acquiring via DirecTV LiL or OTA: OTA Your DirecTV Receiver: HR20-100 Your DMA: Lubbock, TX Your Primary Zip Code (on DirecTV receiver locals setup): 79423 Your Secondary Zip Code (again on the receiver locals): 79424 Did you re-do Antenna Setup (for OTA): Yes Station Callsign:KXTQ-DT (KLCW-DT3) - Telemundo Digital Channel Number: 46-1 Acquiring via DirecTV LiL or OTA: OTA Your DirecTV Receiver: HR20-100 Your DMA: Lubbock, TX Your Primary Zip Code (on DirecTV receiver locals setup): 79423 Your Secondary Zip Code (again on the receiver locals): 79424 Did you re-do Antenna Setup (for OTA): Yes However right now here is the incorrect lineup: 46.1 is KLCW-DT2 MyLubbockTV with KLCW-DT "CW" in the program guide There are two 22.1s 22.1 is KLCW-DT "CW" with the KLCW-DT2 in the program guide. 22.1 also is Telemundo, the program guide is correct just the wrong channel number.
Station Callsign: WPFO (FOX) Digital Channel Number: 23-1 Acquiring via DirecTV LiL or OTA: OTA Your DirecTV Receiver: HR20-100 HR20-700 HRD250 Your DMA:PORTLAND ME Your Primary Zip Code (on DirecTV receiver locals setup):04938 Your Secondary Zip Code (again on the receiver locals): Did you re-do Antenna Setup (for OTA):YES ON HR20s if you punch in 23-1 you get "channel not available" ran setup every day for 10 days On HRD250: if you punch in 23-1, channel comes up, but there is no program info, therefore you cannot program a recording by any method. On tv : channel comes up fine ( strong signal )
11-2 is now fixed, but now 11-1 isn't available through the box.
Station Callsign: KFFX
Digital Channel Number: 11-1
Your DirecTV Receiver: HR20 100
Your DMA: KENNEWICK, RICHLAND, PASCO, PENDELTON
Your Primary Zip Code (on DirecTV receiver locals setup): 99336
Did you re-do Antenna Setup (for OTA): YES
Both problems now fixed but now a new station has went out.
Digital Channel Number: 11-2
11-1 fixed after redo of antenna setup but 11-2 didn't return.
It's now fixed.
Fixed on all machines ! ( now, I can safely pre-program American Idol ) Tx
Frustrated.
Station Callsign: WMBB (ABC)
Digital Channel Number: 13-1 HD feed
Your DMA: Panama City, FL
Your Primary Zip Code (on DirecTV receiver locals setup): 32444
Your Secondary Zip Code (again on the receiver locals): 36301
Did you re-do Antenna Setup (for OTA): Yes - got 13-2 back but still missing 13-1
Glad to find this forum and know it's not just me.
Updated 3/4, these should now be fixed:
WETKDT Burlington
WOWKDT Charleston
KXVADT Abilene
WMEMDT2 Presque Isle
KTKADT Topeka
KSNTDT Topeka
KCENDT Waco
KOGGDT Honolulu
KSYSDT2 & 3 Medford
WGBCDT2 Meridian
KTVODT Ottumwa
Station Callsign: WFXSDT (Fox Network)
Digital Channel Number: 31 remapped to 55.1
Your DMA: Wausau-Rhinelander, WI
Your Primary Zip Code (on DirecTV receiver locals setup): 54487
It comes in when scanning TV tuner, but not on DirecTV receiver guide
Program Guide Shows only 1 day advance schedule
Copy HDD in Directv Box to external drive?
