OTHER - Resurrect my Old C-Band | SatelliteGuys.US
OTHER Resurrect my Old C-Band
3puttbob
25
7
Antelope Valley, Ca.
Hi All
New to forum and with being pandemic sort of homebound, I'm regaining my interest in my old fiberglass C-Band 10ft satellite dish. It's a Curtis Mathis KSX300 with LNA and Feedhorn. Also still have the original G.I. Innovation 450i Receiver. I know analog is pretty much dead and wondered what my options are. I found a HUGHES FSS LNB SAT2 type LNB in my closet. Is it compatible with my dish? Would it work if I by a Digital FTA receiver? Anyone has experience with this type venture? Worth pursuing? Thanks
:welcome to the forum 3puttbob :) Most of us here would definitely say it's worth pursuing. And you can find find answers to most all of your questions here. Pictures speak volumes so please illustrate your questions when you can. You will need a receiver. There are very many to choose from at all price ranges. A good plan would be to look for a popular one that has American support. Cheap China boxes come without support. :( Probably a new LNBF would be ideal too.
Thanks for the welcome. I screwed up. Went up there to look and realized It's an LNB. I don't remember changing it but then, I got the system in 1988. A lot of water passed under this bridge since then.
Hi All
Welcome to Satellite Guys! I would recommend upgrading to a Titanium C1-PLL or C2-PLL lnbf:
and a new receiver like the Amiko HD265:
or Edision MIO.
I would recommend an ASC1 dish mover but they have been discontinued. You may still be able to find one if you look hard.
You can still use the 450i as a manual dish mover though. :)
A little pricey for this country boy only in the respect that I'm not sure at this point of my research how beneficial it would be for my entertainment experiences. I currently have DISH...of course. But, I'm partial to old school.
The above receiver is pricey on purpose just to keep a spot on eBay since the pandemic has caused my shipment to sit on the water. :(
This is what I am also selling and recommending: Amiko MiraX HiS-2000 Hybrid Receiver FTA - IPTV DVB-S2X H.265 HEVC With NTP | eBay
A little fancier, but works good.
Reactions: FTA4PA
Not unless you have an old analog receiver. Most people buy a separate diseqc capable dish mover (such as a Vbox or Gbox) that responds to diseqc commands from the FTA receiver (such as the osmio4k or amiko or similar receiver). Those commands are sent over the coax between the receiver and dish mover. Those commands are then decoded by the dish controller and sends out motor control of the actuator and polarity control for the LNBF. If you are using a regular LNB with polarity control via servo motor then you'll need an old analog receiver. I suggest changing the LNB to an LNBF since it would be less cumbersome.
That's what I meant. If I got a digital receiver, my analogue would be a suitable mover?
I don't know that receiver but if you can move the dish to the right satellite with your remote than you have a good standalone dish mover. :) But once you know DiSEqC you'll never go back ;)
I'll keep that in mind. Appreciate the info. Just want to jump back in as cheap as possible to see if I want to expand. Guess I need to look for a dig. receiver without investing a fortune. Then take it from there.
