Iceberg, I'm in the South Bend/Elkhart, IN DMA.Iceberg said:the SD 105 markets will be moving to either 110 or 129 because DIsh rents the satellite on 105
WHich market are you in?
(BTW, like the new avatar.)
ssmith10pn said:Oh and one more thing. Good Bye FSS!![]()
Foxbat said:Iceberg, I'm in the South Bend/Elkhart, IN DMA.
(BTW, like the new avatar.)[/
Dune said:" HI and AK locals will be on 110
All locals will be available with a Dish 500. (I am guess he means local SD channels)"
How can they put these locals on 110? It takes a seperate dish in HI to pick up 110. I thought that was ilegal.
chaddux said:This has been explained dozens and dozens and dozens of times. NO, it is NOT illegal.
Tony explained it best in this post over at DBSTalk.
Scott Greczkowski said:Altanta will no longer be available as a distant network as it will be moving to the 110 slot on a spotbeam.
Those getting Atlanta as a distant network will be getting New York instead.
Iceberg said:Highly unlikely they would move HI locals off 119 when there is a spotbeam JUST for Hawaii.
mpeltz said:Thanks for the response. This is really disappointing news. I had hoped that they would switch the Atlanta HD locals to the 61.5 satellite. I would love to hear the rational from someone at Dish Network as to why Washington DC gets their HD locals on 61.5, but not Atlanta. If the goal was to have a one-dish setup, then doesn't that apply to Washington DC? I would much rather have a two-dish setup with strong signals on all satellites.
riffjim4069 said:When I swung my 61.5 Dish 500 over to 129 last fall my signal levels were significantly lower...a good 20 points. I quickly swung it back since my signal levels for 61.5 are all over 100+. Personally, I like having two separate dishes because the Dish 1000 and 129 sat are a POS in our area. Having said that, I'm not convinced E* won't be using the Dish 1000 in our area at a later time. In fact, If I were to move 10 miles to my south the Dish 1000 would be standard equipment since I would be in the Richmond VA market.
Killswitchengage, if you have a Dish 129 and a new MPEG-4 receiver (622, 411, 211) then you will be able to receive all the national DishHD channels. However, you will still need a 61.5 Dish 500 in order to receive DC HD LIL recently activated. In this case, I would have to say you were screwed, blued, and tattooed by E*. If I were you, I would have Dish come back out and add a 61.5 Dish 500 and a DPP-44 switch. After they leave, disconnect/cover the 129 LNB and repeak the Dish 1000. At worst, they should leave you with the two Dish 500 solution mentioned by Iceberg.
I really didn't think think I would ever use the DC HD LIL channels (just needed Guide Data) since I have two OTA antennas and even and a stand-alone Sony ATSC/QAM HD DVR, but it sure comes in handy when you're recording an OTA event and wish to view another...don't have to flip to another input or watch an SD local.
The HD locals will be free of charge...assuming you already pay for your analog locals and have an MPEG-4 capable receiver (622, 411, 211, and upcoming 222). The HD locals only consists of ABC, CBS, FOX, and NBC...no WB, UPN, PBS, etc.Killswitchengage said:I don't know what to do. I was told that the 61.5 dish was left along with the newly installed 1000. I guess I'll have to wait when the next installer comes out to install the new switch.
Regardless I have an OTA antenna that picks up thew majors really well. But would love to get the WB in HD which my OTA has trouble with.
Am I right to assume thjat the new hd lil will be an additional cost? Or will it be included with the HD package and the SD locals I allready pay for?
masterdeals said:Is it that simple? Flip the #1 key to make it UHF? I never understood why they made it IR only anyway!
riffjim4069 said:The HD locals will be free of charge...assuming you already pay for your analog locals and have an MPEG-4 capable receiver (622, 411, 211, and upcoming 222). The HD locals only consists of ABC, CBS, FOX, and NBC...no WB, UPN, PBS, etc.
Oh, I just wanted to add that UPN and WB are merging and will become CW. CW will be moved to the new FOX5 DTV tower in the coming months so local reception shouldn't be a problem.
Yep, the Washington DC HD LIL lauched on 1 March and available to customers with a new MPEG-4 receivers. Check out the Channel Chart (6359-6362) and the Press Release.Killswitchengage said:So I'll be able to get the ota hd, local sd and lil hd?? any idea when this will launch?
THanks again for all the info.
Limited time offer
