baloo75 said:justalurker said:Says who?dmodemd said:Yes, BUT, all NEW HD programming will only be on SuperDish...
JL
Says Charlie in the retailer chat!
and many times before, Charlie, retailer, and tech chats...
JL
hemway said:I heard he mentioned th $99 deal again for the 6000 but didn't go into details. Is that true? Does anyone have any information on the $99 deal?
rad said:On 110, TP 7 is HDNet and HDNet Movies, TP17 has Discovery HD and ESPN HD. Now we've been told that 8PSK allows for 3 HD channels per transponder, so isn't there room on 110 to add lets say StarzHD and CinemaxHD or bring back the PPV-HD channel (for example)?
He also said that on next months chat, they will have deals on the model 811.
And he said "ONLY" on SuperDish? --- not "will be on SuperDish" but "will be ONLY on SuperDish".baloo75 said:Says Charlie in the retailer chat!justalurker said:Says who?dmodemd said:Yes, BUT, all NEW HD programming will only be on SuperDish...
JL
Cyclone said:rad said:On 110, TP 7 is HDNet and HDNet Movies, TP17 has Discovery HD and ESPN HD. Now we've been told that 8PSK allows for 3 HD channels per transponder, so isn't there room on 110 to add lets say StarzHD and CinemaxHD or bring back the PPV-HD channel (for example)?
Rad, I think that 8PSK allows for two channels on a DBS Slot, and three channels on a FSS slot. I sure hope they don't try and squeeze three HD channels onto a 110 TP.
The 105º FSS slots are bigger, 26000 signal rate VS 20000 signal rate on DBS and 121º FSS. There are only 24 TP on 105º. 624000 potential total on 105º and 640000 on 120º and other 32 TP birds (like 148º - dish doesn't own all transponders on 61.5º, 110º or 119º). [121º TPs are the same size as 110º and other DBS birds.]Cyclone said:Rad, I think that 8PSK allows for two channels on a DBS Slot, and three channels on a FSS slot. I sure hope they don't try and squeeze three HD channels onto a 110 TP.
We got to get you a video capture card ...Scott Greczkowski said:Ok here are some screen shots from todays chats.
justalurker said:The 105º FSS slots are bigger, 26000 signal rate VS 20000 signal rate on DBS and 121º FSS. There are only 24 TP on 105º. 624000 potential total on 105º and 640000 on 120º and other 32 TP birds (like 148º - dish doesn't own all transponders on 61.5º, 110º or 119º). [121º TPs are the same size as 110º and other DBS birds.]Cyclone said:Rad, I think that 8PSK allows for two channels on a DBS Slot, and three channels on a FSS slot. I sure hope they don't try and squeeze three HD channels onto a 110 TP.
Three HD is doable on a 26000 signal rate TP with the right FEC, but since there is only 24 TPs there the limit would be 72 per bird (no SD channels), which is only slightly better that the 64 possible on a 32 TP 20000 SR bird.
Now if 8PSK allowed for three on a 20000 SR transponder, that would allow for four on a 26000 SR transponder. 96 HD on a 32TP DBS (or 121º) or the same on 105º's 24TP. It all depends on the FEC they can get out of 105º.
BTW: Cool pics of the SuperDish map. Didn't realize coverage stopped at state lines like that. Guess my cellphone map *is* accurate!![]()
JL
justalurker said:We got to get you a video capture card ...Scott Greczkowski said:Ok here are some screen shots from todays chats.![]()
Thanks for sharing.
JL
The ares in Green can get 105 with a SuperDISH, the areas in BLUE can not pick up the 105 satellite with the SuperDISH.
Limited time offer
