AT&T will provide an 8 port Netgear 10/100/1000 switch free of charge if you ask, along with 2 USB wireless adapters.
you definitely had a bad installer...It is up to the installer to provide one
Scott
About to switch from DirecTV to UVerse - a decision based on economics alone. My parents have UVerse, and I noticed that their HD channels appear in letterbox format. Are they missing something in settings, or are UVerse HD channels cropped this way?
I would call into customer service and say that the install was faulty; he didnt ground the outside properly, and he wouldnt give you a switch to connect all your TV's...
I'm sure they will want to come out asap and check the grounding situation,and I assume if you ask the tech nicely, he would give you the switch..
I had Uverse installed yesterday. The DSL is great. TV is good. I have DirecTV HD as well and prefer DirecTV to Uverse so will end up canceling Uverse TV and keeping DSL for now but, may consider going back to Uverse in the future. Primarily, I just don't want to learn the new channel structure now and DirecTV hasn't let me down in the past to make a change. I signed up for the Elite internet package and am getting amazing speed. I am only about 200 yards from the VRAD though.
My home has CAT5e to every room connected to a patch panel in the basement. The RG (Residential Gateway) has 4 Ethernet outputs. I have 7 rooms. Is there one router that would be recommended over the other to connect my Uverse DSL to every room in the home?
Here is a router I found that I think might work but wanted to ask if anyone had any input before making the purchase.
Here is what my speed looks like with the Elite Uvers DSL plan. Awesome!!
Limited time offer
