Thanks for the explanation!Well, basically here is the setup. I only have Paint for a diagram on this PC.
Azbox to 8x1 diseqc 1.1 switch
Port 1 of 8x1 switch goes to a 4x1 diseqc (which then is hooked to LNBs')
Other ports of 8x1 go directly to some LNB's.
In the azbox, I have my switching set as COMBINATION then the order is set as UNCOMITTED, COMITTED
Can you measure bitrate of the mux, ie all channels on same tp ?
Just got my AzBox Elite yesterday.
Had some trouble initially as the cable that connects the front panel buttons and display to the main board had partially disconnected. Thought I had a DOA but I didn't freak out before checking internally.
Maaaaaaaaan, what a thing of BEAUTY!If you haven't got one of these boxes yet, GET ONE! The picture quality on the S2 HD feeds is AMAZING! No problem locking the 9/10 fec's with a 7.5' mesh either.
I don't know why I held off on getting this box after. It's way cool! :up:up:up
Don't hold your breath.Any news on blind scan being added?
Believe me if it was available it would be all over this forum with bunch of owners raving about it.
Till then use another box to blindscan
I do not think the existing Tuner can do it, maybe an updated Tuner Card, who knows.
I have read the same thing on the european forums,they say a software blind scan would take a long time on each sat and it is not worth the effort to do it,but later they may release another tuner that can do it.So if they release one it will be way after it is out of beta,it is not a priority for them,because most hackers in europe do not care about blind scan.Don't hold your breath.
It works for me, just not on most HD stuff - but that is a known thing.Has anyone got the PVR working on it ?
I haven't been doing that long, but seems to be plenty up there, with exception of the recent loss of Equity channels.There does not seem to as much on FTA as there use to be.
has anyone got internal hard drive working in the az Premium ?
put it in and got it to see it showed 465g. acts like it was working but not. even showed at one point it had used a few mg50. but would not play or even show up in the recorded program list.
so i took the hd out put it in a usb box and it recorded and played a less than 2 min. test. with no change to the hd it is formated to fat 32.
when i put it inside last night it did not like me asking it about the storage at first (showed nothing) but after i hit the format button it showed up. it would acted like it was recording but would not stop or respond to the remote,did the hold the power rebot (only function on the remote that seemed to work).
and it would come back with the red lite on the front still on. had to do a back flip off to get that to go off.
running firmware 2238.
what is the hdd delay(i think that's what it said) at the bottom of the storage list
heck this is why i bought the Premium.
one other question anyone able to save the channel list to a usb stick ? and reload.
thanks alot
for reading
I signed up but have not been accepted yet to be a member...
Your account is currently inactive, the administrator of the board will
need to activate it before you can log in. You will receive another e-mail
when this has occurred.
Please do not forget your password as it has been encrypted in our database
and we cannot retrieve it for you. However, should you forget your password
you can request a new one which will be activated in the same way as this
account.
Thank you for registering.
Limited time offer
