Rod and Cam | SatelliteGuys.US
Rod and Cam
ilfoman
105
North
I purchased a brand new 1000.4 Eastern Arc dish on ebay in the new grey paint color, but I notice that it does not have an adjustable elevation rod or azimuth cam.
Does anyone know if these adjustments are no longer required? I am doing the install myself, so would like to know beforehand. Thanks guys (and gals!)
Wrong hardware
Snap a picture of it, but it sounds like they may have sent you 1000.2 hardware instead.
Yes, I think you're correct. The LNBF arm has the holes in the wrong position so it is impossible to attach the adaptor. Looks like the LNBF is OK as the feed horns for 61.5 and 77 are far apart. Thanks for your help.
Yes, the ebay seller as admitted sending the wrong part.
Purchase options to get good installer?
1000.4 dish (eastern arc) question
