RTV,TUFF,PBJ still on 83W? | SatelliteGuys.US
dfecarter
491
39
Connecticut
Was planning on realigning my 4 ft KU dish today, since RTV wasn't coming in well for me on 83W but today I can't receive either of the 3 Luken Chs.
So I figured I'd dble chck and make sure they're still up...suspect they are, they have been in that spot for long time.
Yes, it is...I only get about 48 for quality, thought I use to be able to get more signal when I had the dish at another spot.
well I moved the dish, by loosening the clamps ever so slightly a degree or 2 east, so now I get 83W transponders in the 83w position not 84w (c-band sat)!
am getting RTV and comp. in between 45-51 on my 4 footer, which is about max. :)
8:02pm ET. 11735H 4440SR on the Micro HD 71% quality using 4ft Geosat Pro 1.2m Dish.
It's annoying though, with my motorized KU system...used to be able to pull in 61W-125W, most sats. only at marginal to descent strength, lately 61w-95W comes in strong but I loose the signal moving west beyond 101W, guess it's positioned to where the lower sats. are maximized but I loose the belt when moving westward...real tricky balancing act needed to get better range
Satellite signal meters
Request Opinions on SV-HD8000
