It only does it with my Hopper UHF remote, if I use an IR remote first. Otherwise, it works as it should with my UHF remote.It does it using the DISH UHF remote also.
Yours is the first I've heard of this bug with a UHF remote on its own.
I'm not sure it is posted anywhere else on any other oft-used screens. So, they probably feel this is the best way to get this operational info out there.Yep, I got it last night and that's the first thing my wife noticed this morning. Seems kind of redundant and "dumb" to have made that a banner on EVERY single channel change.
In the past, I could hit format and change the width. I can no longer do that. Too much coincidence with a software update?
Between that and all the obnoxious screen ads at the bottom of many channels, its not going to be long before the banners are going to cover the whole channel when surfing.![]()
You can turn those banners off you know.Between that and all the obnoxious screen ads at the bottom of many channels, its not going to be long before the banners are going to cover the whole channel when surfing.![]()
Why would you want to watch the channels? I mean, you pay for dish to watch the banners, right?
Really?? How do you do this?You can turn those banners off you know.![]()
That's just for the ad banner at the bottom.Go into settings/guide settings/format guide/EPG banner, then toggle the off button and hit the save button
Actually I didn't know, but I'd love to learn how to do so!
Where is the setting to turn those off? I already have the ad at the bottom of the program guide turned off, but the banner ads still show up when changing channels.
Can't turn those off.
Settings > Guide Settings > Format Guide > EPG Banner > OFF
That will get rid of the PPV/VOD advertisements in the guide. Are you guys referring to the banners that some networks air or can you post a screenshot?
Limited time offer
