I am replacing my WSI 6' dish soon. The rust is taking over and I can no longer keep up with it. Can anyone tell me which one is better? Price wise I believe the one from Sadoun is cheaper but I am willing to pay extra to get the better dish.
Is a foot-long better than a regular hotdog?
YES!
SIZE MATTERS!
Go straight for a 10 footer minimum you'll never regret it. But you probably will if you get the 6 footer first, and realize later that maybe you should have gone for the 10 footer right away.
Get plastic dish (Prodelin, Andrew, Channel Master.... etc). Could also be second-hand. Never rusts and great quality.
Is a 10 foot better than a 6?
Will I miss satellites with a 6?
I live in New Jersey
Posted Via The SatelliteGuys Reader App!
Be patient and keep your eye on local classifieds, for sure some day you see something interesting. If I could get made in USA 2 pieces 1,8m plastic Prodelin offsets here, than, for sure some available in USA just waiting for you.Show me where to get a pastic 6' dish and ill be all over it.
Then borrow some dish from people you know and use it as an example to make mold of. But do not forget than mirror itself is only one part of dish. Another part is mount, which, by the way, is not so easy to make. At the end you will spend lots of time, materials (means money), and, possibly, performance of self-made 6-footer will be equal as 3-4 feet out-of-shelf antennas giving.Well if I had the mold of the dish, I'd build it myself using my folks' fiberglass gun at their company.
I also have 3 Prodelin 1.8m dishes, all converted to C band use
Limited time offer
