SAMI 10Ft Dish Opinion | Page 2 | SatelliteGuys.US
Have no trouble with accuracy on my 10' Sami, even rivals some of my little ku dishes for ku reception. If you're having trouble 'stopping on the right bird' most likely that is caused by your actuator. Might check all the bolts on the dish/ring/mount to be sure they aren't loose, also. Replaced all the bolts on mine about four years back, as some were getting rusty.
Dish Size
Transponders
