SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/26/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/26/2007 - 36 changes
Uplink Comparison Range: 05/23/2007 09:50A - 05/23/2007 12:00P -
473 - OPEN1 [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Not Available)
474 - OPEN2 [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Not Available)
475 - OPEN3 [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Not Available)
476 - OPEN4 [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Not Available)
477 - OPEN5 [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Not Available)
612 - SETMX (A) removed from EchoStar1 148W TP 11 ConUS beam
613 - TVASA (A) removed from EchoStar1 148W TP 11 ConUS beam
614 - SET (A) removed from EchoStar1 148W TP 11 ConUS beam
724 - GKINO - Anik F3 118.7W TP 19 ConUS beam changed flags from 01011B6F00FDFF to 01011B6F00FCFF
724 - GKINO - EchoStar9 121W TP 22 ConUS beam changed flags from 01011B6F00FDFF to 01011B6F00FCFF
5631 - KATN1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5632 - KATN2 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5639 - KTVF1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5643 - KFXF1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5646 - KUAC [MPEG4 HD] added to EchoStar2 148W TP 22 ConUS beam (Not Available)
5647 - KUAC2 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5651 - KJNP1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5688 - KJUD1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5689 - KJUD2 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5692 - KTNL1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5693 - KTNL2 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5703 - KTOO [MPEG4 HD] added to EchoStar2 148W TP 22 ConUS beam (Not Available)
5704 - KTOO1 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
5705 - KTOO3 [MPEG4 SD] added to EchoStar2 148W TP 14 ConUS beam (Not Available)
6489 - KOCO [MPEG4 HD] - EchoStar7 119W TP 03 Central Plains beam changed to Available
6492 - KOKH [MPEG4 HD] - EchoStar7 119W TP 03 Central Plains beam changed to Available
7827 - WBGU [MPEG2 SD] - EchoStar10 110W TP 26 Spotbeam 13(MI,IN,OH) changed to Available
9710 - 3ABN [MPEG2 SD] - EchoStar5 129W TP 17 ConUS beam changed to Available
9710 - 3ABN [MPEG2 SD] - EchoStar3 61.5W TP 10 ConUS beam changed to Available
Transponder Changes:
EchoStar2 148W TP 14 ConUS beam changed modulation scheme from QPSK to 8PSK
EchoStar2 148W TP 14 ConUS beam changed symbol rate from 20000 MSPS to 21500 MSPS
EchoStar2 148W TP 14 ConUS beam changed FEC from 5/6 to 2/3
EchoStar2 148W TP 22 ConUS beam 8PSK added to tables
Channels in the system: 3555
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/26/2007 - 5 changes
Uplink Comparison Range: 05/23/2007 12:00P - 05/23/2007 12:48P -
473 - OPEN1 [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
474 - OPEN2 [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
475 - OPEN3 [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
476 - OPEN4 [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
477 - OPEN5 [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/26/2007 - 1 change
Uplink Comparison Range: 05/23/2007 02:32P - 05/24/2007 07:57A -
5682 - KIKU renamed to KIKU1 (NA)
Thanks for the heads up JohnH...
Uplink Comparison Range: 05/24/2007 07:57A - 05/24/2007 08:53P -
473 - OPEN1 moved from EchoStar8 110W TP 24 ConUS beam to EchoStar7 119W TP 18 ConUS beam (A)
474 - OPEN2 moved from EchoStar8 110W TP 24 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
475 - OPEN3 moved from EchoStar8 110W TP 24 ConUS beam to EchoStar8 110W TP 16 ConUS beam (A)
476 - OPEN4 moved from EchoStar8 110W TP 24 ConUS beam to EchoStar7 119W TP 18 ConUS beam (A)
477 - OPEN5 moved from EchoStar8 110W TP 24 ConUS beam to EchoStar7 119W TP 12 ConUS beam (A)
VIP622 not backwards compatable to model 6000
LNB Drift...Is Dish Tech support answer correct?
