SatMex 6 | SatelliteGuys.US
SatMex 6
dexx20
4
Hi, I'm about to default my stb and redo my sat list. I'm missing an active tp for Satmex 6 @ 113w. I would really appreciate it if someone has SatMex 6 scanned and could post an active ku tp for SatMex 6, since none is listed on lyngsat. Any active data tp will do just fine.:)
Thanks.
Thanks.
Here's something from Ice a couple of weeks ago:
so here are the TP's that are active (all data but the 1st)
11818 V 20000-kinda weak
11848 V 10500
11867 V 2500-strong
11930 V 1925-strong
I removed the 1st one, so I suppose the rest are DATA.
Al
Looks like it's AOL Provider? Maybe?
*EDIT*
Yes, it's AOL.. Here's info (11867 V 2500) I got from TSReader:
Code:
Program Number: 20500
PCR on PID 8191 (0x1fff)
PMT Version: 0
Stream Type: 0x06 ISO/IEC 13818-1 PES packets containing private data
 Elementary Stream PID 300 (0x012c)
Descriptor: Service Descriptor
 Service Type: user defined (0x81) Provider: AOL Service: AOL
Just scanned and found 14 Ku channels, since they are not listed on Lyngsat they will not be listed here, try a blind scan!
Could you post an active TP in the WUT? I'm having a little trouble finding it.
amazonas help
What do I need?
