Satwork 3688 Vs Pansat 2500a | SatelliteGuys.US
jackal2403
27
Whats The Difference Between The Blind Search Capabilities Of These Two Recievers? I'm Thinking About Buying One.does One Find More Hidden Channels Then The Other?
Both find the exact same channels, even a non blind/smart scan will pick up the same channels just takes a bit more work.
IMO, after installing all of the above................. It depends on what you want to be doing, if you simply want a blind scan receiver to watch FTA TV I would recommend the Satwork 3688 in a heartbeat, if you are newer to the hobby and you are setting up your first motorized system the USALS feature in the Fortec Ultra and the Pansat can be very useful, and if you can do without the sound on a handful of PBS channels on AMC-3 again I would say save some $ and stump for the Satwork ST 3688, if you want audio with these PBS channels and have a means to decode the AC3 out put, I would say the Fortec and Pansat may be worth the extra cost. They ALL use the same CPU chip! Fair and Balanced : )
free-to-air dish tuning?
Dealing with USALS
