Nice review! Too bad they only put 1 usb 3.0 port on it. I want my EHD and the Hopper GO connected to usb 3 at the same time.
Two words for you... USB HUB.Nice review! Too bad they only put 1 usb 3.0 port on it. I want my EHD and the Hopper GO connected to usb 3 at the same time.
It sure been nice if they have giving it a better look like like 4k model above
Ok good to know that a hub will work on the hopper.Two words for you... USB HUB.
I know as it all ready is but not TV but a PC MonitorIts made so you can hang it behind the TV, so looks really don't matter.![]()
Via sat, right?Yes, movies are $7.99 and I watched the Amazing Spiderman earlier, looked amazing.![]()
SD channels show for me on Hopper 3. Maybe a fix is in the works.Press Guide twice, 3 then under advanced select "Hide duplicate SD channels"
Menu, Settings, Guide, Hide Duplicate Channels...SD channels show for me on Hopper 3. Maybe a fix is in the works.
You must not live with any women.I thought that everybody made a custom channel list to remove all the junk
There isn't at this time. We are hoping dish gives us that option "soon"Is there any way to get rid of the banner at the bottom of the guide? I find it very annoying.
Nope no idea.Scott, do you know the text name that the Carbon UI uses? It looks similar to the DirecTV Genie text.
Thanks.
Limited time offer
