The H3 has an OTA antenna tab. It said to plug the antenna in via the Ethernet port. My Vizo has a digital tuner which is connected to an outdoor antenna. So would I plug the Ethernet cable into the TV & H3 ports?
Does the Joey 2 connect to the Hopper 3 using coax and the solo node? Thanks
I transferred my timers form my H1 to H3 just fine with my 40 remote...
Yup.And you can backup your timers to the Remote COntrol and restore them to the Hopper 3.
So, how to I convince the tech to leave my 40 remote with me when he takes away the Hopper 1? Or will he let me transfer the timers before taking it away, hopefully?!
I read on this forum that the 40 remote works with the H3. I plan on trying to do anything I can to keep my 40 remote in case I don't like the newly designed remote.
When I placed the order for my upgrade I asked for the OTA USB tuner. The CSR said that the installer will have one on the truck. Is that true?Actually, for OTA reception on the Hopper, you need to get a special USB OTA Adapter that Dish produces for the Hopper:
https://www.mydish.com/support/usb-digital-ota-tuner
Once you get that, you connect your outdoor antenna into the Adapter, which plugs into one of the Hoppers USB ports. Many of us have one, and they work quite well!
I cannot agree with this. The Hopper OTA is very poor compared to the TV that is connected to same antenna.Actually, for OTA reception on the Hopper, you need to get a special USB OTA Adapter that Dish produces for the Hopper:
If it is like going from Hopper 2 to Hopper 2 then it should bring your custom guides along too. I had a Hopper 2 die and found the timers, custom guides and wireless setting were all transferred. I hope it is the same for H2 to H3.Wow, I had no idea the remote could do this, that is great. Now I just have to figure out how to do it.So, how to I convince the tech to leave my 40 remote with me when he takes away the Hopper 1? Or will he let me transfer the timers before taking it away, hopefully?! I will also get an external hard drive as well to backup my current recordings. Lost everything last time I upgraded 3 years ago and hoping to avoid that this time.
I just ordered the OTA USB attachment from Dish for $30 plus tax. Just need to sign into your mydish account and order one up.Not sure about that...I don't know if they carry them or not. If they don;t have one, you should be able to order one directly from Dish and have it shipped to you, or you can find them on Amazon, though I think Dish actually sells them a bit cheaper.
Powered USB Hub so you can use non powered drives! I have been doing that since I received my Hopper w/sling no issues to date.Two words for you... USB HUB.
Wish I could say the same been almost a day after getting the message for my info and have not heard anything back, however my card has had the $1 test hold put on it.Excited.....getting mine installed on Saturday! Thanks for the review Scott.....
BTW, the DIRT Team rocks. within 10 minutes of receiving their response to my interest, I had an appointment scheduled!
Limited time offer
