Maybe a dumb question. How are you all "moving" like that?
I still get OTA guide data for Seattle-I will check 10-12 days out. There is more information now for OTA. The program guide is in Central time, but I'm getting used to it. You will lose FOXNW though if you move out of WA or Portland.
Curious how the move is holding up over time. Do you still get channel guide info for Seattle OTA? Do you get the local regional sports for Chicago? I was holding out mostly for FOXNW for the Mariners. But I have to admit I would enjoy watching Lou's antics with the Cubs. My signal for 129 tp 12 is above 90 so it should work.
I get all the channels without trouble in Mill Creek. OTA is funny. Your next door neighbor might get everything and you might still have trouble. I was told by a pro to just forget it, but after working on it I do get all channels now (big hill blocks my path). Last night was very windy and had hickups with Prison Break. But what I do is record (622) both the HD and the SD. So halfway through the show I just switched it over to SD. I had NO problems this year with any Seahawks recordings.
We are all hoping that KCPQ does come online eventually. But if you've read through this thread you can see how frustrated we've become with that.
If I had a free choice right now I'd still go Dish.
We have a big hill between us & the Seattle towers & a lower but wider & closer rise in elevation between us & KCPQ's tower. When we first got the HDTV a year & a half ago, the first scan found KOMO but I've never found anything since. What are you using, Chuck? Maybe I'll give it one more try.
For what it's worth, I just filed an FCC complaint online (Form 475). Tribune can stick that in their pipe and smoke it!
I have been a Dish Network subscriber for years, and I have enjoyed Dish's HD rebroadcasts of local channels. In Seattle NBC, CBS and ABC are all rebroadcast on Dish Network in HD, and it works perfectly. However Fox is not available.
From what I understand, the problem is a dispute between Fox and Dish over redistribution rights. Normally I would be fine with that, it is a free country, but in this case it smacks of unfair business practices. The reason for my concern is that Fox is retransmitted fine on Direct TV, but not on Dish Network. Since Direct TV is owned by the same group as Fox television, it seems that they are withholding the channel for anticompetitive reasons. In fact Direct TV representatives have even suggested to Dish Network customers that a possible recourse is to leave Dish Network and go to Direct TV.
This is anticompetitive, and unfair. I would hope something could be done.
Limited time offer
