Second, Third . . . Satellites | SatelliteGuys.US
phiaso
I have set up the receiver to work with the motor by going into the "Install Antenna Menu" and choosing the first satellite (T5), LNBF, Diseqc, etc. Then, by going into the "Channel search" menu, I found the channels on T5. Now, I want to look at other satellites. Here is my question , specific to the Coship CDVB5300B receiver. To "store G3C as one of the satellites," do I have to go back to the "Install Antenna" menu, or can I go directly to the "Channel Search" menu (or some other menu)? Another question: In the satellite lists on these two menus, the last entries are New Satellite01 . . . . How to enter the location of a new satellite in this area? Thanks.
_________________
My setup: SG-2100 DiSEqC 1.2 H-H motor, COSHIP CDVB-5300B, 3Hot Dish 75 30 inch disk, ASC321S Ku LNBF
Hello and Welcome to the SatelliteGuys.US FTA/MPEG-2 forum!
Hopefully someone with this specific receiver will be able to help you. I guess you have seen the below link/Manual but I thought I would add it anyway so that everyone knows what box you are referring to, all the best : )
http://www.dmsiusa.com/cdvb2300.htm
Do I have the right gear?
FTA MPEG on Existing Analog questions
