Separate dish for Ka 103? | SatelliteGuys.US
kobe8
17
Is it possible to set up a side dish to pick up D* HD locals on 103? Can I use a standard 18" dish? Where can I find a Ka lnbf? Thanks!
The only dish available for the Ka at 103 is the AT9 dish due to the frequencies used only the LNB on the AT9 will work.:)
Does D*upgrade for free or do I have to buy it from a dealer?
Is there a multiswitch available for the AT9?
The last thing I want to do is get into some other contract with them for a dish.
Thanks!
Thanks!
You need a H20 for the AT9. Zinwell makes a Wide Band multiswitch for it.
Got the H20, just need the dish now. Thanks for the info on the Zinwell product. I've been reading about a new slimline dish coming out though. I might wait for that one.
If you have local HD in your area I would go ahead and get it. I am not sure of the price. If locals are not available wait for the slimline.
Columbus, OH HD locals apparently delayed (surprise)
H20-500?
