Setting the skew on a 3 ft. dish | Page 2 | SatelliteGuys.US
vinny6ft said:
Not familiar with Direcway.....but this dish is just a larger version of dish that SD uses in Canada....eliptical almost oval...and with a larger mount and is thicker.... I have an arm from a smaller 80 cm dish that will work to hold the lnb...I really would like to access a 120 cm eliptical dish in Mexico....
One more observation, the lnb arm needs to be the one made for the antenna as the focal point is specific to each diameter and shape of antenna. Using an arm from a smaller antenna would place your lnb inside of where the focal point of the signal is.
