SG 2100 Blues | SatelliteGuys.US
SG 2100 Blues
BubahJim
64
Bluefield, VA
Hello Guys,
Got a problem with my Motech SG2100 and I thought I would again ask the wiser minds here for ideas. The SG2100 motor is hooked to a Winegard 2076 dish and has worked faihfully for 14 months. It opperates manually fine (pushing the buttons on the motor itself. Using my my Fortec Ultra reciever (inside)it does not work. I tried different cables, LMB's, etc. no change. Any ideas on what the problem could be? Again thanks for the advice and time.
Bubahjim
May have to do a factory default on both the motor and receiver as a last resort, if you do not have another receiver to try.
I would go back to the "0" zenith position then reset both motor and receiver.
Its in the SG2100 manual how to do it.
With the power on use a paper clip to push the button under the motor, and keep it depressed until the light changes from green to orange then back to green again.
Noob Mtr Dish combo setup question?
What do I need to get Galaxy3 or PAS9?
