SG2100 Schematics | SatelliteGuys.US
SG2100 Schematics
xtra
55
Halifax,NC
Anyone have the schematics for the SG2100. My DC motor quit and I checked the diodes on the board above the DC motor and I have an open diode. I need to know the value of the diode so I can replace it.
What is the diode labeled? its probably a 1N4148 (standard silicon switching diode) or something like that.. not sure what you mean by "value", as diodes dont have a value, but more generally a type.
diode
it says 104 on it and I couldn't find one so I ordered a new SG2100 motor. THanks anyway.
Its a 1n4104, standard zener diode. you can get them at radio shack.
the line above most likely says 1n4
Black plastic with a silver strip on one side if I recall correctly
will pole hold?
sg2100 and winegard76cm
