Shaw Direct Satellite connection | SatelliteGuys.US
Henry Sanchez
84
8
California, USA
Hi Satellite Guys community, i have a couple of Shaw Direct satellite installation doubts:
Do i need to use an special switch if i want to connect two HD 600 receivers with One 1.10 meter offset satellite dish? a dual standard lnb installed on it. In this case, the satellite dish is pointing to Anik F2 only.
The other question is: What is the proper/correct installation if i want 2 offset satellite dishes pointing one to Anik F1 and the other one to Anik F2, with dual standard lnb's to each satellite dish, for one or more than 2 satellite receivers?
Is there a kind of wiring diagram or something i should read first?
I really appreciate any help or suggestion about this Project...
