should I install a WNC AU2 antenna? | SatelliteGuys.US
eugeneg
15
north dakota
I live in North Dakota at the Canadian Border.
I have an old sony antenna which is pointed at 101. It's reception is quite good.
I have a wnc au2 antenna which I bought a number of years ago and didn't install. I am thinking of installing it now that I have some time to play with the installation and the setup.
Any recommendations?
Is this an 18x20 3LNB oval dish???
If so, unless you are wanting spanish or other international prog, what IS the point?
What little HD is left on it will NO longer be there by around the end of the year.
Sometimes, having something simpler is better... ;)
I thought that it would pick up 101 110 and 119.
It does - & again, there isn't anything on those other birds except Spanish, some Chinese, a few leftover HD channels which WILL be going bye bye by the end of the year, & local channels from other markets. You have to PAY to get those foreign channels as well, which are NOT cheap. I'm assuming you are NOT trying to get locals from other markets, either.
It's NOT going to make your reception ANY better on the 101 bird, either.
So again, what extra channels DO you think you're going to get by switching dishes... :confused: :confused:
Quite honestly I can understand practical advice.
I did not know what was on the other satellites and was asking what I thought was a simple and civil question.
I was happy with Dishrich's response. However boba decided he was being left out and had to pop in his two cents.
Thank you to you dishrich.
DirecTV announces second quarter 2009 results
New H23 Receiver local HD questions
