Signal Strength | SatelliteGuys.US
Signal Strength
billshort113
9
I'm at 67% and I've got nothing on the VU meter.Is that normal?What percentage of signal strength do you need to get a good recording?
It is not normal,
You should see something. I sounds like an audio card setting issue or you are not plugged into the Line-In of the sound card.
Please open a support ticket from our website and a Support person will help you out.
Derek
I'm wondering the same thing. I just installed TT for Sirius. I'm showing 33% signal strength for each satellite and nothing for terrestial. Is that sufficient? I'm having major problems getting TT to work properly and would like to eliminate signal strength as the culprit.
33% should be fine for recording.
Terrestrial will only show a signal if your city has a terrestrial antenna.
(Where are you located)
Check out this page for detailed Sirius antenna setups:
http://www.sirius.com/getsirius/homeantenna
If you are not hearing any audio or getting VU activity try the following:
1) Go into the Levels setting of TimeTrax and make sure all the inputs are correct. (It is the clickable on the main screen that says "Levels")
2) Make sure that on the Configuration screen of TimeTrax the proper recording device is chosen.
3) Go into the Control Panel, then into Sound Devices, click Advanced and check the playback properties and make sure Line-In isn't muted etc.
4) Check the recording properties and make sure Line-In is selected
Follow these steps:
1) Control Panel
2) Sound and Audio Devices
3) Advanced Tab
4) Options
5) Properties
6) Adjust Volume for "Recording" (Click OK)
A new mixer will pop up.... make sure that Line-In is selected.
Click the "X" and see if that helps.
Feel free to open a support ticket if you would like further help.
Derek
Terrestrial Strength shows as 0%
36 hours and then it SUCKS
