Sleep mode = Coma | SatelliteGuys.US
Sleep mode = Coma
AIsmail
214
27
Stewartsville, NJ
I've had no major issues with my 922 except for the fact that when it goes into sleep mode its more like a coma. When I go turn on my TV after a long period of time I find screen saver is paused on the screen & when I push "Select" the unit fails to wake up. I think it started with the latest software update. I then have to reset it from the front panel. I've found turning my receiver off rather then letting it go into "sleep mode" on its own to be somewhat helpful. Has anyone encountered a similar problem? Thanks.
My 922 does that frequently as well. I have an autotune set up so it will be on our local news channel when we get home from work. The orange and green light will be on the front of the unit, but when the projector and Onkyo receiver come on, there will be no picture or sound. I usually have to do a red button reset to get it to come on. Sometimes pushing "Select" or "Power" in some combination will cause it to reset itself. It can be really annoying if there is a recording in progress when this happens. BTW, my 922 has had 108 installed for some time now.
sling problems/ home media problems(please help)
Lost Eastern Arc and 110 Signals
