Slimline 3 Tilt/skew | SatelliteGuys.US
gohard113
4
pa
Can anybody tell me what is the tilt/skew for the direct tv slimeline 3 dish? Also I'm on the east coast (PA) and would like to know which satellite I should be pointing to?
Can anyone tell me what the Tilt/Skew is for the slimline 3 dish? Also can anyone tell me which satellites I should be picking up? I'm on the east coast (harrisburg Pa). Thanks!
Go to http://dispointer.com, enter your address and from the drop down box select one of the multisat entries for DirecTV.
You should then be presented with the alignment parameters for your location.
You use the satellite setup menu on your receiver.
Address: harrisburg Pa
Latitude: 40.8100°
Longitude: -73.9620°
Satellite: DirecTV SL3 (99W, 101W, 103W)
Elevation: 35.3°
Azimuth (true): 218.0°
Azimuth (magn.): 231
Options
show obstacle (line of sight checker)
Your LocationSatellite DataDish Setup Data
Latitude:40.8100°
Longitude:-73.9620°
Your Skew is 62.2º
Name: DirecTV SL3 (99W, 101W, 103W)
Distance: 38159km
Elevation: 35.3°
Azimuth (magn.): °
Dish Skew [?]: 62.2°
ESPN Glitches
HR34 700 Genie Questions
