Slimline vs AT9 Dish | SatelliteGuys.US
OneBigJedi
SatelliteGuys Guru
133
For those of you who had an AT9 dish and have upgraded to the newer Slimline dish, which one do you prefer? Is the signal any stronger? Is it easier to peak the Ka signal?
Let us know! We may need to switch!
Agree with Jimbo; never had an issue with either.
I have not had a bad wet snow yet, but I'm sure it will work, I can't expect it to wipe itself off of the snow, so I plan to wipe it down when nessasary.
the only way I can see it not collecting any snow would be if it were straight up and down and then you would not pick up any signal, I guess that might be at the North Pole.
jimbo
If it snows that much in my area, make sure you have said your peace with the world. LOL. But I can relate to the 2 or 3 monsoonal rains each year at max.
VERY, VERY RARELY down here in the valley; or under 3000'. We had a freak snow fall up in Scottsdale about 6 or 7 years ago. Super powerful winter storm whipped through and it managed to snow at the lower elevations. Gave a good dusting and was gone after a few hours at best. But yes, it does snow in AZ all the time. Just not like in CA or NV. I am right around the red dot.
Do you "do snow"? http://www.snoweye.com/
Hr 20 100 to 700????????????
HR20-700 Dolby Digital audio issue
