Slingbox TV2 Solution | SatelliteGuys.US
MohaimenK
12
Hello guys. I just came accross this IR to UHF converter.
solidsignal dot com/prod_display.asp?PROD=ES123804&xzoom=Large#xview
Now my question is, shouldn't this work for Slingbox TV2??? Couldn't I put the IR transmitters infronf ot this and then transfer that into UHF connection and use TV2 for my slingbox?
I am just confused because I keep finding info where Dish is coming out with with a UHF to IR but shouldn't it be the other way around???
Slingbox doesn't have UHF connection, it has IR connection. So how would converting a UHF connection into IR help?
BTW, I am using a VIP722. Any thoughts on this?
Picture only in corner of screen/722
VIP SD aspect ratio
