small dish c band | SatelliteGuys.US
small dish c band
Yes but I guess it depends on what you were looking for. My C band dish is only 42"/38" inches and I get the Island networks on G-16 which is on a fairly weak transponder. Using my 36" Pansat dish I can get LeSea networks on G-16 easy.
I wish to get AMC 1 rfd at least in central florida west coast
a simple search would have shown you wont get that
a 5 footer you will probably have some issues. Ever since they put up AMC18 (105W C-Band) my reception on AMC1 has been questionable at best with the 6 footer
Ion & TLN (KTLN & KEEN) I can get with a 45 quality on the Pansat which is good (30 is threshold)
DW-TV is a 7/8 FEC so I can't keep that signal stable. You need at least a 70 quality to keep that stable
RFDTV I get barely a signal. The HD feed on G23 (121W) I get at a 60 quality
http://www.satelliteguys.us/c-band-satellite-discussion/183986-5-foot-c-band-dish-question.html
and some more info
http://www.satelliteguys.us/c-band-...ccurate-lyngsat-footprint-figures-c-band.html
Liberty University Football
more than on lnbf on one 38'' dish
