snh-031 | SatelliteGuys.US
snh-031
cobrage401
29
Hello all I have a snh-031 and qnh-031 lnb on my 90cm dish with the 2100 motor and a 3500sd. my question is can some one give me a good sat to point to for the snh-031 with a good tp and lnb setup information. Also what birds can I use the snh-031 with I live in NH at 03235.
Thanks all
Dave
is cubavision fta,ku, or c band? will i pick it up in nh 03235?
Cubavision International is on Ku Band - Yes FTA - can be found on 58.0 W
New Hampshire ? No Problem
That is unless you have a Obstructive view of the South Eastern sky.
11612 H 3670
Frequency 11612
Polarity Horizontal
SR Symbol Rate 3670
: and by the way I got lazy and didn't feel like checking my receiver for the info so I went to Lyngsat which is very handy to look up Freq: POL: and SR : for Cubavision International.
Heres the link to Intelsat 9 ( formerly Pas 9 ) info on Lyngsat .
http://www.lyngsat.com/intel9.html
Lyngsat is a great tool , I'm sure just about everyone here has used it at some time or another , just remember that Ku frequencies are 5 digits long and on satellites that transmit C-band and Ku you can just scroll down the list till you find the 5 digit frequencies , to the right you will see info on where the signal is being aimed example: North America , and if you click on it you might get a diagram of the footprint , then you can get an idea geographically of where the signal is strongest and weakest.
Dear Abby
Please verify:
