Or I should say, are getting hooked up to DirecTV, because they just purchased a new HDTV
Anyway, they're moving from analog cable to DirecTV and live in Central Wisconsin (54427) - I'm confident that they'll be able to pickup both ABC and CBS with an off air antenna in HD, but the local FOX station (WFXS) doesn't even broadcast in HD
The other FOX channel [which does broadcast in HD] (WLUK) is too far away to even consider.
Now, I checked on DirecTV's DNS webpage to check eligibility for them, and for WFXS they're listed as Grade A (strong signal) which makes sense, they're only a few miles from the station - but again, it's not broadcasted in HD. Because they're listed as a "Grade A" the website says they are not eligible for DNS coverage.
Is that the end of it? No FOXHD coverage for them? Or can I contact DirecTV and explain the situation?
