so what is my ebno? | SatelliteGuys.US
so what is my ebno?
Techfizzle
Banned
985
OK i know how to pull up the screen, but i don't know what it is in the mess of data.
Also is it true the battery voltage is on here to, if so what is it?
you have to go to diagnostic C to get the EBNO.. from this screen use the arrows on the remote to go thru to C.. then on the right hand side you'll see ebno
edit: oops.. hit button too soon.. from this screen right arrow twice for diag C
yeah no duh...probably means 1.2 :D
or he is locked on something like Bloomberg that I locked at 9.0 on a 4 footer
Yeah my 920 shows around +10.5 or so + or - a couple points on most of the GB channels with the 7.5ft dish.
google is your freind
the energy per bit to noise power spectral density ratio that is ebno
its basicly a little better reading than signal quaility
this is odd my ebno is 12 on any sat (everyone told me my dish could never be peaked on an unlevel pole:p)
if i peak the dish, and move it a bit east and west. my ebno stays at 12
my ebno never goes higher then 12 even though i can move it a bit and it doesnt go down, why?
what is it on HBO? Mine dropped to 9.4 to 9.9 from the 10's i was getting on C3.
digicipher II wid feeds?
Info on what receiver and lnb for 10ft B.U.D
