Software Update | Page 2 | SatelliteGuys.US
Software Update
Unfortunately It's something that just happens.
I wish they would rename upgraded files like this to something else so way this does not happen.
So the Java file is named javafilev2 instead of javafile. So this was in a new update the system looks for a pulls javafile2 instead of the old javafile one.
This is on thing that stinks about caching. ;)
No Problem Scott ....
It May have already found the correct file as I haven't see the error since, keep in mind it's only been a short time.
I saw the issue with the times that Foxbat had yesterday but upon a page refresh or two things were back to normal. :)
Yes, a refresh made everything here good as well. iPadOS v18.3.1 and the current Safari client. I figured it was a weird caching issue...
edit: and it just happened to my new Mac Mini with Sequoia v15.3.1 and Safari Version 18.3 (20620.2.4.11.5). A Command-R to refresh and it had the correct time, not "later today at x" (which sounds like Elon and his DoGE Hounds have injected a redirect to X)(JK)
Reactions: charlesrshell
New wrinkle: it started by saying "tomorrow_at_x" and when I went to get a screen capture, changed to "later_today_at_x". It definitely sounds like a Clock issue. Is there server in the right Time Zone? Is the board properly set up for Eastern Standard Time? Or, is the clock maybe behind a few minutes and the Client Clock tries to resolve the Post Time and it's in the future.
Or, like TRG suggested, is it in orbit around a black hole and proceeding at a slower pace than the rest of SpaceTime? ;)
Here's another clue: it seems to happen most when I click on the Reaction Alert (so-and-so Liked your post). See:
The forum runs on whatever your forum account locale is set for (Eastern, Central, Mountain, Pacific, Hawaii, etc.).
I'd imagine that everything is referenced to GMT (as many modern servers are because GMT never suffers Daylight Savings jumps) and the user locales take care of any conversions. I can't see a properly coordinated date showing up in the future unless there's some bad PHP code that ignores the time zone offset established by the locale.
Most properly configured Linux servers get their time from the ntp utility once the system is up and running and that works around any settings with the RTC of the mainboard. Another utility, ntpdate is used to set the RTC and system time on a one-shot basis but that's typically not very useful for a system that ideally never reboots.
Windows will fail to update the clock using NTP if the BIOS date is too far off but I don't think ntp cares about any differential that might exist.
It's spreading:
Another thought. Is it possible the Server time is off? Or is it possible that the timestamp is returning a Null date time value?
Down in the "Similar threads" section, I looked at one of the similar threads which was from December 2022, so items from years ago are showing up "in the future".
Just now, first time I viewed later_today_at_x under Latest Posts.
I asked Xenforo about it and they said sooner or later the browser will update its cache.
The time it happened to me, I press Control and Refresh and the problem went away.
My monitor has been reporting high CPU usage at 2am when the backups are being done. With GZIP being the culprit, so this morning I switched GZIP for PIGZ which is multi threaded so it should handle things better then GZIP. :D
Other than that everything seems to be working well on the new server. (thank god!)
Can you disable caching on the guilty Java applet code? Or whatever it is that the client browser downloads that causes this issue? If I recall my web server days under the MS umbrella, you could set a file (or directory) to customize the caching age limit, or disable it entirely.
Just an update... I am informed others are reporting this issue as well over the past few days. And its NOT a Xenforo (forum software) issue. Its an issue with an update to the Google Analytics Plugin that was also updated.
The author of the program is aware of the issue and working on a fix.
Not loading on iPhone
Welcome to the NEW SERVER!
