Sonic voom how to? | SatelliteGuys.US
Sonic voom how to?
cruzin
323
michigan
After buying the sonic zoom head set how does one set it up to play through the tv? as usual thanks in advance.
thats how I have mine hooked up too
receiver------rca cable from spdif output----sonic voom input
sonic voom headphone output------Y adapter as posted above----TV rca inputs
I think I got it. You plug the fiber optic cable from receiver to sonic voom then you get a y adapter and plug that into the front of the sonic voom from there into the red and white of the tv. But what about the orange rca cable for the sonic voom? Do you not use this orange one?
Has the coolsat 5000 receiver setup for the audio been covered on the forum?
thanks for the help.
The orange cable can be used instead of the fibre optic cable...its one or the other
otherwise you got it right
GloryStar-Religious Programming
Unusual hardware, but a good find??
