Sous Vide | Page 8 | SatelliteGuys.US
Sous Vide
I've never heard of "Angus Choice" Picanha. Maybe just local?
It comes from Angus cows and is USDA Choice:
  • Wow
Reactions: navychop
I purchased this over the weekend and cooked it last night. I don't have a sous vide so I baked it in the oven at 390° for 70 minutes to 140° internal. It is everything navychop said it might be, delicious and tender. I used a recipe that called for kosher salt only. I might change that to kosher salt, pepper, and granulated garlic next time (and there will definitely be a next time.) :)
I don't think I've ever done bacon or sausage Sous Vide. How does that compare to a frying pan?
I would really like to play with sous-vide but... I like rare to medium rare. Mrs Bobby is more medium to medium well. I would have to have two setups.
Just out one in a few minutes after the other.
Anyway, chicken and pork are generally done to the same doneness.
I have two for that reason. You could also pull the rarer package and turn up the heat for a bit to cook more.
That's what I often do- but I'll try your bacon grease idea. I also use a searzall torch once in a while, or smoker to blast furnace, especially for rib racks or other oversize items.
Quick and Easy
Snacks...
